Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Sep 07, 2007 2:52 am
.020" overbore isn't a whole lot. It adds .5mm to the overall diameter of the cylinder. I'll be using wiseco's 86.5mm pistons.
Also, with a .020" overbore, it's possible to retain the stock headgasket if I feel going in the direction is the way to go. But with the wisecos raising compression a good half a point or more, I'm considering going with a thicker metal head gasket to relower my comp.
Rosco, I suggest going to a good local machine shop and discuss with them the pros and cons of overboring. A good shop will have done so many motors that they should have most , if not all, the answers you need.
One thing I will note that I've heard, but never really seen as a fact is that you might see some structural integrity issues past a .020 overbore because the cylinder walls get too thin. But I've only seen that in sales pitches for cylinder sleeves.
Bullet, I'm still a ways off from the rebuild. I'm waiting on a hookup to order my pistons, and then the block can finally get to the machine shop to have everything checked, decked, and bored. I'm hoping within the month to have the block to the shop and back.
I'm also going through midway for my timing chain pieces. My last chain job on my current motor was done with aftermarket, and I payed about $125 for it 3 years ago. It's held up very well with no rattles, bad tensioner, or anything. The kit had everything. Gaskets, chain and guides, tensioner, and sprockets for cams and crank.
I'm going with midway this time around because I can pick up the guides, bolts, and chain for $150. I had picked up a tensioner a year ago thinking mine was bad, but it turned out it was good and I was just being paranoid.
I figure for a minor extra expense, OE will suit me better. But don't be afraid to use aftermarket parts. They're not bad.
