OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.html
Sun Dec 12, 2010 5:37 pm
About 30 minutes ago, I started the Q for the first time since I started the chain guide, fuel injector, alternator, pulleys, belts, hoses, rocker cover reseal, knock sensor, power steering pump re-seal, and general engine compartment restoration project. LOL
Honestly, I was shocked when it started up faster than the Honda this morning. What a non-event!
The first run was for 1 minute, second for 2 minutes, third for three and so on.. No leaks anywhere so far.
The power steering pump picked up a lot of air in the system as makes the classic whining noise. It may take a while to work the air out of the system. The car is sitting on jack stands so I've been turning the steering wheel lock-to-lock.
As soon as I get up from this computer, I will be taking the laptop with ECUTalk downstairs to run a full round of diagnostoc tests. I know the IAC valve needs to be adjusted as the idle is too fast.
I've got a few tests to run using a TCU from a 1994 model -- also with the NICO ECU.
I'm not sure how far I will get here tonight as I've been up working on it for the past 36 hours. I just wanted to have it running before Monday.
Many thanks to everybody here for all of the great technical guidance.
Will post more tomorrow.
Craig
