gs14racer »
https://forums.nicoclub.com/gs14racer-u58274.html
Mon Oct 13, 2008 2:54 am
Definitly a fuel issue, i had very similar troubles when my fuel pump died.
You have only a few possibilities, either you have the fuel lines inverted, your losing fuel pressure somewhere (ie loose hose in the tank etc, pickup came off the pump in the tank), the regulator is bad ( doubtful), or your pump is bad.
but there is a more stupid possibility, are you sure you have gas in the tank, i once chased down a horrible hesitation issue just like you described. I didnt have the fuel gauge connected and the tank was dry, the motor started and idled perfect just woulndt rev up.
Good luck
