IT RUNS!!!! couple of problems, but i don't care
spider_slayer
Car: S14 240SX
S13 240SX
update: some of you may not remember but about 4 months ago i started an engine swap. i've been working on it about once a week for the past few weeks and now it runs. w00t!
anyway the car idles at about 1700 so i'll try adjusting that tommorow.
would like to ask for your guy's input though.the car idles at about 1700 once warm, while driving and coming to a stop the idle will just to about 2200 then fall to 1000 and repeat before it setttles to 1700 grand. anyone think the timing may be off? or maybe jsut the vac systme is dirty and needs to be cleaned?
S13FASTBACKSR
Car: '92 Fastback SR powered
if the timing is off you'll feel some misfiring/hesitation. are you having any other problems? try cleaning your iacv and tb and dont forget about them vac leaks
FliMSiCaL
Car: 1989 240sx 1994 sentra limited edition
if your idle is fluctuating rapidly up and down, check your o2 sensor, it may be malfunctioning.
S13FASTBACKSR
probably not the o2 sensor though because you would be running rich...spiderslayer do you have any other problems other than bad idle?
neo_s13
spider_slayer wrote: while driving and coming to a stop the idle will just to about 2200 then fall to 1000 and repeat before it setttles to 1700 grand.
holy crap 1700 grand? so its idling at 17,000,000 rpm?
lol sorry just had to bust your balls on that......ok ok i take it back
ArcadeMod
Car: 240 SX
I know that if EGR valve connections arent plugged properly it makes for vac leaks which might cause that.
