WDRacing wrote:Lookin good man....My tunbe with the SAFCII is pretty solid on boost. Dunno why your's isn't. Mine goes from 11.4 at peak torque then up to 12.7 on a steady rate of increase from 4200 to 7000 you can almost draw a line with the AFR's.
No alky either.
It could be that I was monitoring this stuff on my own, without someone else there to help. It's always nice to have someone in the seat next to you monitoring the wideband. I think I can get it a bit closer, now that I think back on it. I really didn't spend a lot of time on it. Not to mention that "street tuning" is inconsistent at best, since the loads change.
Either way, I won't dwell on it much, since the BikiRom/550's/Z32 MAF will be coming in a month or less. No need spending dyno money on this current setup. I just need it to drive safely and dependently on this "generic" tune.
Modified by KATwo40 at 4:55 PM 1/30/2006
