It Lives w/pics long post need help
SET240SX
Car: fast rides
Finally the big moment of truth. I install the fmic and finish wiring up the harness in the battery area. Time to get some oil pumping. So i remove the plugs and turn the engine over watching the plugs for fire and there is (woohoo). So i disconnect the ignitor chip and a few revolutions later i got oil to the valve train. Turn it over awhile longer just to make sure the oil is flowing to everything. I install the plugs and turn it over and it doesn't even try to start. So i am like dam i hope i didnt fry anything. Maybe its just flooded. Well i can't find anything wrong with the fuel and about to pull the plugs again to check spark and it hits me like holyfield the ignitor is not plugged in LMAO. Plug it in and turn the key woohoo nice rumble. First time my 240 has ran let alone the sr20.
Alright i still have a problem. When i connect the battery cables the headlights come on and will not go off. Anybody got any ideas?
I disconnected the 2 harness plugs in the battery area because i rewired them according to HT,didnt change anything.
I took the headlight switch out of the dash still the headlights are on. High and low beams work i just cant turn the headlights off.
The only other place the harness was messed with was changeing the dash plug.
ThxPhilip
Rican_Nick
congratulations man... except for the the lighting thing.. i have no idea what that could be off the top of my head.. but anyways i hope to crank up my blacktop tomorrow.. I cant wait.. good luck man
quiksilvia
Car: 95 s14 se
how long did it take u to drop the redtop?
SCOOTER240
Car: 1990 240sx sr20 black top
it sounds as if you may be feeing power directly to the headlight circuit-double check your splices and find the wire that leads to the headlights-not the one to the switch-find this and your problem should be solvedgood luck!!
SET240SX
Car: fast rides
Quick The actual install itsself was probably about 3 days. Although it took me almost 5 months from the time i got me motor set do to waiting on parts.
ScooterLooks like what i will be doing tomorrow. Was hoping somebody might have ran into something similar and could tell me where to look first. I have a few more resources on monday morning to contact.
Thx for the inputPhilip
quiksilvia
Car: 95 s14 se
thats what im expecting
slw240sx
Car: 1990 Ca18det 240sx Hatch
congrats! and is that a blitz IC?
240_Keyy
Car: '90 240 Fastback
no it isn't a blitz, one too many couplers on the passenger side. I am guessing greddy...
SET240SX
Car: fast rides
slw240
Thx No that is the hks type s IC. I wanted the blitz but everybody says there on order not sure when its getting here. Wayne at phase2motortrend talked me into the hks. He said it was the same core as the blitz only real diff is the hks piping is powder coated ( explains the cost).
98TURBOKA
Car: HOME IMPROVMENTS-MOUNTAIN BIKING- EARNING MONEY-MOVIES
Dude your car just winked at me!! Tell her I'm taken, I don't want mine mad at me.
SET240SX
Car: fast rides
LMAOThe tease winks at eveybody.
slw240sx
ahh there all the same ! just have differant piping and names stamped on them !
BuudWeizErr
slw240sx wrote:ahh there all the same ! just have differant piping and names stamped on them !
He speaks the truth. It's more piping quality. I like the Blitz, then HKS, then GReddy. The endtanks and brackets are different on all the models also, but that doesn't make a difference.
slw240sx
greddys piping sucks!!! mine tore a hole into the cold side from rubbing against the jaggd rusted metal .. good thing i finnally put some rubber hose around that metal to protect it
