CA18 RS13 »
https://forums.nicoclub.com/ca18-rs13-u1319.html
Sat Jun 21, 2003 11:08 am
Big thanks go out to Sean for letting me borrow his stuff, and also to everyone who helped me out.
I finally got to pick up the spare ECU Sean is letting me borrow and once I threw it in the car started up with some hesitation. After keeping the throttle held down for a while I let it settle down to idle. The car idled very ruffly for a long period and then I test drove it a bit and it blew out some smoke when I got on it slightly. After leaving it on for a while longer the idle seems to be coming back to normal, but the voltage is still hanging a little low, and the car falters a bit when reved up then you let off the throttle and let it go back down to idle, but it recovers.
In diagnostic mode 3 I am getting a error code 34, which is the detonation sensor. Does anyone know if I can pick this part up off a CA18DE? Also the one bit of bad news is since my ECU is fried, my chip most likely is also, so I will be needing another one.
If anyone has a spare ECU or two to sell let me know so I can get Sean his back ASAP, also if anyone knows where I can get another chip burned (preferably based somewhat on my mods, fuel cut removal, speed limiter removal, 550cc injectors, Z32 MAFS) I would appreciate that also.
