it just won't start
angel_d
i have a 1991 240sx that just won't start. i had a mechanic from a nissan dealer change the starter but the car still won't start. it won't even try to turn over. every time we turn the key, it just makes a vage "click" sound. the battery is fine and tested. all the lights, radio, etc. works. can you please tell me what's wrong with my car
navysnail
if the timing chain broke or skiped, you may have bent valves. the click is probobly the starter solinoid or relay. is the motor trying to turn ( is it getting power when you turn the key).
angel_d
it won't turn at all.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
You need to determine whether the click is coming from the starter or a relay somewhere.
bcar240
Car: 1993 240SX HB
how did it stop? did you just come out one day and it didn't start, or had you been having engine trouble. was it acting strange before it quit?
blacks13ek
I had the same problem. Check to make sure the battery cables are secure and check for a little metal object with a lever on the left side of the battery. Play with the switch. Thats what fixed mine. Sucks cause i spent 60$ for a guy to just use a manual and flip a switch :(
silkk
Car: 94 B13
89 S13
07 S2000
check your fuses
silkk
Car: 94 B13
89 S13
07 S2000
wait.. is it an automatic? i used to get the same problem with my automatic sentra
