dhen wrote:float_6969 wrote:My pistons do something similar, but they're CP pistons and slap around and make a lot of noise when they're cold as well. The CP's do it because of the aluminum that is used. It's very resistant to detonation, but has a high rate of expansion.
If those are stock pistons, you might look in the FSM and see what the acceptable clearance is. If it's out of spec, that could be the noise.
Thanks. I forgot to mention that mine are forged Wiseco pistons. Any idea if they're supposed to do the same? Since they're not stock, how do I find out if they're in spec? Sorry if that's a stupid question.
You should have received a sheet with your forged aftermarket pistons stating the required clearance. My forged CP's are also frigtheningly loose in the bore when cold. They are +0.5mm oversize, but the cylinder bore needed to be ~83.42mm for the correct clearance, instead of 83.50mm, like common sense would have you believe. Good thing I didn't send the block to the machine shop before I got the pistons.
If you have forged pistons, don't go by the FSM, always go by the sheet you got. If you don't have the sheet, get ahold of it first. (This might come late though, now that your engine is already put together, machine work done...
Did you assemble your engine yourself? Were your pistons this loose at assembly time? Do you know what clearance they were assembled with? Do you have the Wiseco's data/installation sheet?
