oem belts from dantech in advertiser's forum, or courtesynissan.com.sanioll wrote:=================================================questions of a newbie:
What size of belts should i get?
What make are the best, or at least meet the oem specifications and quality?
Where can i get them? store? web site?
Can you provide a pic? Not necessary, but could be useful.=================================================
sanioll wrote:So, simply make some room by removing regular stuff.
Use adjusting bolts to loosen the belts, then take out the old belt and put new one in and re tighten with up to the recommended point provided in FSM.
That soap method is hardcore, haha, watch those fingers for sure. You can get that aerosol belt dressing from parts store, safe distance of fingers from running belts.eddiec wrote:aside from replacing the belts, another way of eliminating the belt squeak is with soap. use a bar of saop and while the motor is running rub the soap on the pulleys (be careful of that fan). it will of course spread itself around and knock the noise down.
about those adjusting bolts, for me the p.s. was the hardest to loosen up. i dont know if it was because of the hicas pump or what but it was a pain
lol that reminds me of my friend when we were rebuilding his engine, went to autozone to get a rear main seal.ddgsxr504 wrote:Anyway forget autozone! They are good for parts not tech advice on imports!!
pretty much but there is a bolt that the accesory rotates around as you adjust tension, and if it is to tight no matter how much you loosesn the tensioner bolt the accesory itself won't move so sometimes you need to loosesn the adjusting bolt and the mounting bolt if that makes sence to you...sanioll wrote:AND FINALLY, THIS IS HOW YOU CHANGE IT RIGHT: ?????
those tools are a ripoff. Take a ruler and lay it flat accross the belt then take another ruler and puush down on the belt with it, read how far you pushed the belt down on the second ruler using the first ruler as a reference point.ILikeMy240sx wrote:speaking of belts... where can I get one of those tools to measure how tight your belts are? Mine is starting to make squeaking noises at 3000 RPM and want to check if the belts are tight enough.
Thanx
NOT REALLY, could you show in this pic?Red coupe wrote:pretty much but there is a bolt that the accesory rotates around as you adjust tension, and if it is to tight no matter how much you loosesn the tensioner bolt the accesory itself won't move so sometimes you need to loosesn the adjusting bolt and the mounting bolt if that makes sence to you...
ok, so you push with 22lbs of force... its a belt, not a freaking jet enginesanioll wrote:you gotta apply 10 Kilograms/22pounds of downforce on it i believe.
confirmed, here:
Modified by sanioll at 3:41 AM 3/1/2005
look at the pic above. IT IS FROM '92 S13 FSM.IveBeenBad wrote:ok, so you push with 22lbs of force... its a belt, not a freaking jet engine
You dont get what I'm saying. It is a drivebelt, it doesn't need to be exactly on spec. All you are checking is to see if it moves a certain distance so that you know it wont come off... easy enough to eyeball... if it moves more than 1/2" tighten it a bit, but not so tight that its near breaking...sanioll wrote:look at the pic above. IT IS FROM '92 S13 FSM.
*sigh* sure that explains all the half-assed jobs done around here.sanioll wrote:I guess were a bit of perfectionists here when it comes to our 240s.
