Well! I guess I can say that Nismo_Freak was right and you’re not really close til you’re driving it. In my case I did drive it and it actually put me further away from the joy of being happy with my newly self-rebuild ride. (See here:
zerothread?id=133450)
Well, now she has about 80 miles on her since yesterday finishing up rebuild, and she sounds great. Except for a damn vacuum leak somewhere in the intake manifold, I think it’s the injector o-rings sucking air in, because they are a little older and don’t seal like the should. That’s ok, I’m just breaking her in on the stock 270cc, then I’m going back to the 460cc RX-7 ones, and those have brand new o-rings and seals. The crappy thing is that the car spent about half a tank going those 80 miles, and I’m not sure why. Is this normal for newly re-built engines? Is my O2 sensor shot? I leaned it out a little bit (5% from 1.5k to 3k) with the SAFC, but I don’t think I should have. This could be because of the vacuum leak, right?
Another thing is that I didn’t realize just how stiff my newly made (polyurethane glue/paste) engine/transmission mounts would be. It’s pretty rough especially on idle, the booming deep engine rumble is pretty bad inside the car. When I get over 2.5k it’s not bad so highway is just regular exhaust noise (which is not too bad since the turbo muffles pretty good). Outside the car is much quieter than it seems when you sit inside and are overpowered by the engine vibrations at idle.
Well, with the giant radiator, when not using a fan it doesn’t overheat while driving, but the temps go up a bit at stoplights. So I let it warm up w/out a fan and then turn it on when I start driving. I think I’ll get one of those temperature probes that turn the fan on as soon as a certain temperature is reached. Anyone know of a cheap one?
I taped two magnets to my oil filter to let it collect the crud that amounts as the rings wear in, so far both my oil changes showed very clean oil with lots of microscopic metal shavings in it. You know what I mean, like the oil itself is not brown, but when you see it, it has stuff in it. It’s in one of the pics in the above posted link.
I’ve disconnected the wastegate actuator for now, so the WG is always open, because I’m breaking it in, I’ll start boosting it after this tank of gas (which was full yesterday and is now half empty after 80 miles) is done and I change the oil again.
Ok here are some pics of the engine bay:Turbo side
Turbo side 2
Intake side
Could I BE any happier
My new (20 years old) shiftknob from Russia, the frikkin thread pattern is the SAME as on a Russian car from the 80s! It’s amazing.
Thanks all who helped and gave advice, please continue to do so, you guys are great!
sil80
Modified by sil80drifter at 3:44 PM 9/3/2005
