It begins
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
My walbro 255 pump arrived today, 480cc injectors and SAFC-II will be in next week.
If I install the walbro, do I need to install an adjustable FPR with it, or does it retain the same fuel pressure? Are there any issues I should be aware of when installing this on an s14 other than having to use the stock fuel sock (and not the s13 sock included)?Thanks
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Some have seen the base fuel pressur ego up a couple PSI with a Walbro...mine is now and was always ~43.5 (vac line disconnected).
So you *shouldn't* need an adj. FPR...
Other issues: None.
- Brian
