ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Thu Jun 23, 2011 5:56 pm
Pop the hood, and squeeze the fuel rail both sides and remember what it felt like, now start it up, get it to run then go and feel those rail fuel lines again.
On the second squeeze did they feel harder, like a bit higher fuel pressure. If yes, the fuel is escaping the lines and if the check valve is not working fuel is bleeding back to tank...a possibility! Cracked fuel lines, dirty fuel filter, leaks, check throttle body for wet spots.
By the way when was the last time you checked spray patterns of the injectors, plug gaps, ignition wires and spark?
