Is there anyone here that knows how to test transistors? Here is a link to the datasheet for a particular transistor that I want to test. It is a NEC K591.
http://pdf1.alldatasheet.com/d....html
Here is a link to a page that describes how to test the transistor.http://www.kilowattclassroom.c...7.pdf
It says that I need to know if it is a PNP or an NPN transistor. I also need to know which is the collector, the base, and the emitter. It says to refer to the data sheet for the transistor to find out which it is. When I look at the datasheet, it says gate, drain, and source for the 3 pins. Anyone have any ideas which is which?
Matt
