martymcfly1 wrote:Installed Kenwood works great, everything.
Decided to purchase the back up camera.The directions that come with the camera are less than desirable.Got camera mounted and ran cable back to HU.Ran purple/whit strip wire to back up light and attached.
Now at the HU side of the BOYO wire there is the obviously the composite wire and the red (+) and the ground (-). BOYO says in broken english (e-mail). Attach camera to back up lamp and ground. Here in lies my question.
Can I attach the (+) from the BOYO camera to the purple/white stripe from the Kenwood. This wire does go back to the back up light and then attach the other wire (Black) to ground at the HU side?
It would have made more sense if BOYO had made it possible to connect the power to the camera at the rear of the vehicle not at the head unit.
Does any of this make sense?
Help? AppleBonker or rjdmmfl1? Anyone?
1st, as usual, what applebonker said is 100% correct. The best way to hook this up is *** the directions stated! AGain, as previously explained, by hooking the unit up to an ACC on source, you can look behind you while driving forward. THis helps in situation of towing (not likely for our vehicles) when you want to keep an eye on the tailgate.
Also, the RCA power/ground is on the same wire as the RCA, and since you have to run the RCA up front anyway to connect to the rear view camera input on the kenwood, it only makes sense to run the power/ground up there along with it, and just splice the power/ground to the power ground for your headunit!
Although I will say I hate how small those power/ground wires are on the Boyo camera... they're like 26 gague or something!
