Issues with crankshaft position sensor s14
Moggrob
Car: 1995 240sx ka24de
So heres the story, i bought an s14 last week and it had a check engine light for a crankshaft position sensor. I check the sensor and it was loose in the bell housing and just floating there, the plastic broke between the bolt and the sensor itself so i bought a new one and installed it and now i have a loud ticking comming from the location of the sensor and i have no idea what could be causing the issue, i called the dealer to see if it was missing a gasket or o-ring but they said it doesnt have one. Any help would be greatly appreciated.
Moggrob
Found out the issue, the flywheel was grinding at the sensor and i ended up having to buy another one and put 2 washers under the sensor and now it runs great and so far no cel
Hijacker
Car: '92 240sx Convertible
'94 F-150
Glad you got it figured out!
PapaSmurf2k3
Site Admin
Yup, I was gonna say it sounds like a gap issue, and to pull it out and check to see if it's all Fubar.
