jrd450r »
https://forums.nicoclub.com/jrd450r-u48236.html
Fri Nov 28, 2008 11:42 am
My motor is basically stock, just 3in exhaust, front mount, 255 walbro, adjustable FPR. It runs perfect till about 10-12psi, then all hell breaks loose. I am running my waste gate line off of intake pressure so the waste gate should be opening ~12psi. It just backfires and misses like all hell when it hits this point. I tried switching from iridium plugs to coppers, this made it run a little better down low but i'm still having this problem up top. My plugs are gapped within spec, but on the tight side as I thought I was blowing out my spark with the boost, but It still does this. My fuel pressure is also within spec. Its frustrating cuz it runs perfect up until this point. Any help would be much appreciated! Thanks!
