Postby
Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.htmlTue Oct 01, 2013 9:34 am
It's not the brake light switch's fault. There are two rubber bumpers at the brake light switch, one for brakes and one for cruise control. One or both probably fell off.
Check how many bumpers you need then order them at the dealer. It just pops in.
Postby
Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.htmlSat Oct 05, 2013 8:31 am
For the leak below the power steering fluid reservoir, replacing the hose should fix the problem. Your dealer should have the correct hose (the hose leaking is the power steering return line). If you want me to look up the exact part number, post your VIN and I can look it up.
Have you ever changed the power steering fluid? Dirty fluid may have damaged the power steering pump's seals and caused the leak. You can try using a high-mileage automatic transmission fluid like Valvoline MaxLife ATF (if available in your area) as power steering fluid, it may slow or stop the leak.
Postby
Towncivilian »
https://forums.nicoclub.com/towncivilian-u161382.htmlMon Oct 07, 2013 8:55 am
Part number 49725-4W011 is the power steering return hose you need from the dealer.
Use a suction gun (like this) or a turkey baster (like this, but one you will not use for cooking again) to siphon the power steering fluid from the reservoir, then fill with a high-mileage automatic transmission fluid. It may slow or stop the leak from that area.
