issues... fuel pressure s13
gtune4
Car: toonah
well my f.p. gauge has always been around 36-37 at warm idle, recently i noticed that it is now chillin at 40-41?what could cause this other than vac leaks, my car is pulling fine vac..
Gladius
Did you recently change your fuel filter?
lee_harvey
Car: 93 nissan 240sr
do you have an adjustable FPR or is it stock?
DanielIser
Car: SR20 Powered '91 240SX
better than where mine is sitting atm, 5-10 lbs of fuel pressure at idle. If i give it gas there is no bottom end power, but it will eventually catch up as fuel pressure builds some!
DriftBandit
Car: this is my 3rd 240sx
Do you have the stock fpr, It is pretty prone to going out, Get the adjustable FPR, its worth the money if your stock FPR is going out-Jon
gtune4
Car: toonah
using the adjust. fpr do i just install it and adjust the pressure according to my gauge?
