DrifterProdigy85 wrote:Do it if its what you really want. Saurus Garage or whatever there name is in Japan runs the Tomei ITB setup on there S15 Silvia. Seems like a badass setup but im not willing to pay the money for that. Ill stick to my 90mm TB on a SRI Manifold.
I would really like to do an ITB setup, i've always wanted to do one on something.... However I'm planning on doing a metric a**-ton of homework on it if I do plan on doing it.
I mentioned earlier about the engine analyzer pro program. It's extremely accurate, that being said I would probably have to get a lot of information on various parts of the stock KA24DE before I figure out the specifics for such a setup.
The main things I need to know first is...
How well the stock intake manifold flowshow large are the stock intake and exhuast portshow large the intake and exhuast valves are (diameter wise)
and that's pretty much all I need from there. I've got everything but that info...
Then I'll plug in that info, save it as a stock ka24de, then modify it with the gt2871 .68 turbo in the program. Then I'll just play with runner lengths and surge tank sizes til I get what I want.
As I've said before it will be a very thought out process, I'm going to be going for the most responsive and powerful powerband that I can run, and unless someone can make a evo3 16g (or preferably the hta68) compressor fit to a t3 twin scroll turbine housing then I'll stick with a gt2871 variant.
