lvdisturbed1 »
https://forums.nicoclub.com/lvdisturbed1-u226760.html
Mon Oct 28, 2013 2:17 pm
I decided to give her a spin down the street to determine if it would be safe to drive to a shop 3-4 miles out. As expected, heavy smoke out the tailpipes. I pulled over when I saw a little smoke from the hood again. Fire extinguisher in hand, I investigated. Still couldn't determine the source, but I believe its oil. Not happy with the short trip, I decided to head back home. As I park, I discover the smoking from the tailpipe subsiding. Curious, I leave the car running for a bit. I pop open the hood, and the smoke from the engine bay was almost gone as well.
Perplexed, I figured I would wait a few hours and let the engine cool down again (from normal operating temp, it wasn't overheating). After 2 1/2 hours, I start her up again. This time no smoke out the tailpipe, and no noticeable smoke from engine bay. I figured it was worth another shot driving, so I went around the block a few times. Still no smoke, and running better than before I had changed the connectors.
Theory time. The car was definitely driving better. It had a little more power than before, so it is possible I was running it on 5 cylinders for awhile and didn't know it. There may be a small valve cover leak in that cylinder that wasn't running, and after changing out all the brittle connectors, it burned off the oil that accumulated now that it is running again. It took that short trip to burn out the oil in the cylinder, and now its good. Plausible?
If that was my issue, I'll get the valve cover gaskets redone soon. I may as well upgrade to the newer style injectors when I do the plenum pull. I'll update in a few days to report how the car is running.
