I have installed a Vh41de into a nissan skyline R33, but I have one issue I cant resolve which is that when I activate the neutral switch the engine will stall after 30 seconds with no error code, things I have checked is fuel supply from pump to engine all ok.
I have an 92 fgy32 motor, that is running a T5 Borgwarner manual Gearbox, the engine will run for ever and a day out of neutral but as soon as i ground the neutral signal wire it will stop running with in seconds.
I have checked all wireing from engine to ecu everthing is ok, also the eccs and ignition relays all stay activated and working ok dureing and after engine has stopped running.
I am hopeing that someone has had this issue and could possibly help, the only reason I want it sorted is so that I can set base idle, but with the engine stalling after 30 seconds in neutral this can not be acomplished.
The only code logged is 55 no fault help please, my ecu keeps turning my engine off in neutral.
