94_240sx wrote:
Isn't this it?
zerothread?id=205732
4cedkoop,It sounds like your alternator might be going bad. You better check it out. It should put out 14.5v or something like that constantly. Problem is... if it goes bad completely, you will have to tow your car, so make sure your alternator is generating enough power. Wiring on alternator and belt are also common things to check.
SO!!!!! It's FIXED!!!! And you sir.... are the man for finding that thread. I don't know if those wires for the auto antenna were bad, but, I took out the jack, and individually insulated the wires. Plugged the 2 antenna plugs back in. And I put a new 10amp fuse into the dome location. Took it for a drive. My door ajar and the interior lights kept blinking. My passenger door wasn't closing enough to put enough pressure on the door switch. I tried moving the door latch on the body to hold the door in more, but, that didn't work. So, I used double sided tape and now I'm good. No more problems besides the seatbelt light stays on ALL THE TIME!!!! Lol, I'll prolly just pull it. Both belt harnesses are still connected, so I'm not sure what the deal is.
Here's the thing, I'm smarter than this, lol. I had no idea that the dome fuse being out would cause all that to happen. Maybe it was a combo of the wires and the fuse. I checked the wires over well, and I didn't see any cuts. Anyway, bottom line, it's fixed. Thanks again guys.
I'LL TAKE TWO 240sxConvertible stickers now please..... who and what do I need to pay?
