So i take it no one knows the answer to this......NIzmoS13 wrote:I have a really big issue with my clutch system on my 240sx its a 93 KA and i just replaced the clutch it-self and slave cylinder recently. I just started getting alot of pressure in my clutch pedal to where it builds so much pressure that is starts slipping to correct this problem i just released the pressure from the slave cylinder and it good to go pulls great but then back to square one again builds pressure in the line and starts slipping been going on for about 2 weeks. Anyone got any ideas what i need to do fix or what im doing wrong in correcting this issue?
NOTE-I also replaced the master cylinder as well but did not fix the issue at hand.
20 minutes and you're giving up? Patience bro, patience.NIzmoS13 wrote:So i
Awesome i will go ahead and look into that thanks for the update. the dampner can be removed completely (not needed) for the clutch line ?scottydog wrote:I think your clutch dampener is crapping out. There is a valve in the box that gets gummed up.
Remove the dampener, reconnect, rebleed. You should be good to go.
Yes. Some guys carefully bend the hydraulic line around, some get a short line to reconnect. It makes the bleeding easier also.NIzmoS13 wrote:the dampner can be removed completely (not needed) for the clutch line ?
I will try removing the dampner first. re-routing the line sounds like a project all in it self but if the dampner does not work thats what i wil have to do thanks for the update. .rockinthefans wrote: Try the hose or get a one piece stainless steel line that runs from the master cylinder to the slave cylinder and be done with it.
