So I picked up a new toy....89 s13 coupe. Pics to be thrown later.
Problem starts- It boggs horribly under load at around 2k and sometimes at 3k. I've replaced the MAF with another one obtained by a friend, and the TPS. I also have checked each cylinder while the car was started, by pulling the plug wire from each cylinder one at a time. After pulling each one, it runs a BUNCH worse, so its firing just fine on each cylinder. It also SEEMS to get better at idle when I play with another sensor inbetween the throttle body and the valve cover(not sure which sensor this is....maybe coolant temp sensor?).
Any ideas?
Modified by joshmeyer at 8:29 PM 10/19/2009
