issue O_O
b-13det
Car: b-13 SER
turbo spools but i get no pull, also around 4k-5k RPM the car limits me from going any higher(neutral i can rev it up all the way but i choose not to). i check for leak but i have no leakage any where. i am using a bluebird ecu with the stock SE-R MAFS i was wondering if that was the problem. i am pretty sure i got the fuel system pretty good down, 370cc injectors w/ Warbro fuel pump FPR/gauge(set at 40lb idle). if that mafs is the issue i guess i am just going to buy a tune ecu
Modified by b-13det at 4:47 PM 2/8/2009
nametakennow
Car: '06 MINI Cooper S
Where in your setup is your MAF? Have you put a wideband O2 on it to see how your A/F ratio looks?
What ECU setup are you using? Any piggyback computer?
Please resize your sig to follow guidelines as well.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
what is the boost pressure getting up too under load. the wastegate maybe stuck open. didn' t u have an issue with the bov being stuck open in another post? if that is the case the car isn't going to build boost properly, ever. maybe you should keep all you turbo related issues to one post so we can keep up.
b-13det
Car: b-13 SER
MAFS is next to battery and under the intercooler pipe. currently using a bluebird ECU. also haven't bought wideband or a piggyback computer
nametakennow
I meant is your MAF before or after the turbo, sounds like before, so that's not it.
Like RED said, what is your boost gauge reading? Is this with the BOV still stuck open?
b-13det
Car: b-13 SER
that is with BOV not connected( mad surge)
Modified by b-13det at 5:20 AM 2/10/2009
nametakennow
I wouldn't be pushing it til everything is installed, personally. It could be as minor as a boost leak or the BOV being stuck open, but if you're hitting full boost it could be a fuel issue, which would mean possible detonation and such.
b-13det
Car: b-13 SER
nah, just stock 8 lbs. but everything is pretty much done. just need boost gauge, and air fuel ratio gauge. (boost gauge is on other post)
nametakennow
8lbs isn't much, but if your ECU isn't adjusting like it should be you can still be doing damage. Given your symptom of not being able to get into the higher RPM range, it's entirely possible it's a fuel issue. That's why I brought that up.
b-13det
Car: b-13 SER
So i need a tune'd ECU? Because mines is just a stock bluebird with a stock USDM MAF
moersfelng08
Car: 1996 200sx SE-R
You're using a JDM BB ECU? We've come into problems using those which is why on my B14 i just sucked it up and had it my SE-R one re-tuned.
RED_DET
Vendor
2011 Infiniti G37x
Do you have an upgraded fuel pump (walbro)? That ecu should run the car perfectly fine, but there is an occasion where they don't. I couldn't get my stock blue ecu to work properly. It wouldn't idle properly or rev and when I turned the car off it would still run and no there wasn't a turbo timer hooked up. You may need to get an ecu from calum.
b-13det
Car: b-13 SER
yes, i do have a warbo fuelpump., injectors are 370cc. and when i do turn on the car, it does idle like crap. when i take the car to higher rpm, feels like fuel cut off? something has to be uberly wrong. i was going to get it tune by E-MANCE but a couple of my friends go there ECU tune by him and blew there motors, they say he not that great but IDK
Modified by b-13det at 5:19 AM 2/10/2009
moersfelng08
RED_DET wrote:Do you have an upgraded fuel pump (walbro)? That ecu should run the car perfectly fine, but there is an occasion where they don't. I couldn't get my stock blue ecu to work properly. It wouldn't idle properly or rev and when I turned the car off it would still run and no there wasn't a turbo timer hooked up. You may need to get an ecu from calum.
These are similar to the problems I have encountered trying to use the stock ECU, but it's happened a total of 3 out of 4 times (not including this current build since I went JWT)
nametakennow
Get a Calum or JWT ECU and fix your BOV issues before you blow something up.
b-13det
Car: b-13 SER
is there a safe way to drill a hole through the firewall for the boost gauge line? cuz i really cant find the gromit where the speedometer gauge goes through.
b-13det
Car: b-13 SER
unless its the stick bluebird ecu, then yes. lol.
nametakennow
Can you find any hole to go through? I found one on the passenger side more or less behind the glove box, but it wouldn't surprise me if that was a B15-only thing.
The problem isn't so much drilling itself as where. You'd have to figure out a spot that's going to come through where you can actually use it.
RED_DET
Vendor
2011 Infiniti G37x
follow the throttle cable into the firewall.
b-13det
Car: b-13 SER
okay, got it. thanks!~!
b-13det
Car: b-13 SER
bad news.......engine lock up after drop in ECU and try to test if i have boost. sat in the car crank but everything locked up, but i guess ill get a new one ^^
