96Qowner »
https://forums.nicoclub.com/96qowner-u19561.html
Tue Jul 10, 2007 5:29 am
No, the ethanol absorbs water from the atmosphere - humidity. It absorbs more as the temp and humidity rise. When it cools, the water separates back out and settles to the bottom of the tank, along with some of the ethanol. When it warms back up they get reabsorbed, etc. So, essentially, in the morning after the car has been sitting and its been cool, you have a tank of gas with two layers - a top layer of gas with very little ethanol (and low octane) - and a bottom layer of ethanol-rich water. The same thing applies to the tanks at the gas station.
Gas doesn't absorb much water, never did.
Isopropyl is water-starved already - artificially distilled - so it sucks up water and doesn't release it. Both ethanol and isopropyl with water dissolved in it burns just fine - the water all burns off. But cooled ethanol lets water settle out of it, corroding stuff and making your gas mix unpredictable.
However: My high-mileage Accord - currently 388,000 miles, all my miles - has been run on 10% ethanol almost exclusively over 17 years. I live in a freezing climate. I have never, not once, had any sign that water or ethanol caused a problem of any sort in the car - nothing - ever. No gas line freezing, no corrosion, no coughing, nada, zip, nuttin.
