ISO Float 6969 or other knowledgable source of info
Brocephus
Car: 1984 Pontiac Fiero
Hey Ryan, do you have a list of 5 speed manual trannies that will bolt up to the CA18DET? If you do, do I need to be "year-specific" or do they all pretty much bolt up with no trouble?
If there are different trannies, which is the most preferred? Reason I ask is, I am entertaining the thought of looking into making that Fiero AWD. I know it could be done, all it takes is money, finding the right parts, and a helluva lot of luck.
Just curious to see if I can still utilize the CA or if I'll have to switch to a Subaru power and driveline to accomplish this. If I do, then I'll most likely just stick with RWD and get this right first before I go attempting the insane. :-)
Oh yeah, what is the class number on the manual transmission? I know the Auto is something like "GA16" or something...
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Brocephus wrote:Hey Ryan, do you have a list of 5 speed manual trannies that will bolt up to the CA18DET? If you do, do I need to be "year-specific" or do they all pretty much bolt up with no trouble?
You may be in luck. The CA actually came in AWD. I would contact Pulsar GTR on this board. He may have access to one.
float_6969
Chris nailed it. I assume you're wanting to use a FWD style AWD layout? It was available in the CA that way and would be the simplest route.
If you're talking about a RWD style transmission any S13/S12 transmission should work as long as it was designed to bolt up to a CA series block. The S12 trannies bell housing are shorter (from what I hear) and you may have to cut the shifter hole out a little to get it to work. I'm not sure about driveshaft length.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
The S12 bell is the same length, it's the rear section that is shorter. The S13/S14 trans is longer than the S12's.
pulsar gtr
Car: NISSAN VEHICLES
If you are going AWD, you definitley want to consider the AWD of a pulsar gtir as it is plug and play, I might have access to one. Let me know if you are still interested and if you can't find one localy.
Thanks,
RafiPULSAR GTR
NeedCAforS13
Car: CA swapped S13 coupe
unless you put the motor in the front its not going to work. the driveshaft going to the rear wheels comes off the transmission towards the back of the car. And if you're thinking of putting the motor in backwards, you would have 5 reverse gears and 1 forward gear. Same reason you don't see any AWD mr2's. Its not because the 3SGTE doesn't come AWD. Its because you can't make it work without a custom gearbox.
Sean
NeedCAforS13
and GA16 is another nissan motor. Just like a CA18. or SR20. its actually a GA16DE. It doesn't mean auto transmission. Most if not all of the GA16's probably CAME with auto trannies, but thats not the name of the transmission.
CA19DET
WTF, are you doing with a carib label as your avatar, that is made locally here in trinidad lol
NeedCAforS13
and its soooo f'ing good. I went to Nevis on vacation and they make it on St. Kitts (next door). haha
my fridge is full of that stuff! <3
Sean
float_6969
OHhhh, it would drive backwards, hunh? Man, I just got a little smarter today...
NeedCAforS13
haha yeah I was wondering why the words "Float 6969" and "knowledgable source" got mixed up in the same sentence...
Sean
float_6969
There has got a be a rule somewhere about forum co-moderators bashing each other....
