ISO compressor clutch hub
TN_INFINITI
Car: M35X
Anyone have a spare a/c compressor clutch hub plate for a 2008 M35x? My compressor is fine. My clutch is fine, but my compressor clutch hub has broken. The rubber bushing sheared loose. I used epoxy and have a temp fix, but would like a more permanent solution.
FYI, the compressor clutch hub is the metal plate that comes off when you loosen the 10mm bolt on the front of the compressor. It contains the shims.
I can't seem to find just this part for sale, and i'm even having trouble to find the entire clutch assembly with electro magnet and clutch hub. If I can't source just this part, i'll probably be looking for a salvaged compressor (it's a shame to buy the entire compressor with clutch just to get the clutch hub, but I can probably find a salvaged unit for less than a new clutch).
TN_INFINITI
Car: M35X
Will any Nissan Maxima aor Murano compressor hubs fit?
Otherwise it might require a trip to the salvage yard or eBay for a used compressor w/clutch hub
LIBRILZ
Car: 1990 Nissan 300zx
2007 M45 Sport
I suggest just buying a used compressor off ebay, they are not very expensive
