Which means before the filter right?WDRacing wrote:After the turbo, so it can cool the oil after it gets super heated by the turbo itself.
Any install pics? Where did you locate it, just infront of the radiator?duncan351 wrote:Yup, I'm running run. Another friend of mine with an SR has one too. No issues.
I'll have to object to this one. Unless you run a separate pump to do this, the oil in it will likely not move very well through it. The typical location of a turbo on a KA or any motor for that matter, will leave little room to put an oil cooler that is effective and able to run completely on gravity. On a street car, I would run one that is thermostacially controlled/bypassed. It is possible to overcool motor oil and do more harm then good. Street driving will create very little excess heat in the oil. One that thermostacially bypasses the cooler when temps are normal would be ideal as it would do nothing until you need it.WDRacing wrote:After the turbo, so it can cool the oil after it gets super heated by the turbo itself.
All rx7 oil coolers have built in thermostats correct?duncan351 wrote:Yea Steve you're right. I have a thermostate in the oil cooler and the sandwich adapter. So I think I'm covered there.
The thermostat in the oil cooler works just like that in your cooling system. It's in the end tank by the inlet and outlet. If the oil isn't hot enough it will just go from one hose to the other. When it gets hot enough it runs through the cooler and out the other hose.karmakaze wrote:Not to go and bring up an ancient post of anything... because obviously i would never do such a thing, but i was wondering, how in the hell does the thermostat in the RX7 cooler work?
it only has 2 lines going into it, so is the bypass internal?
Correct!brokeAs240sx wrote:All rx7 oil coolers have built in thermostats correct?
go on rx7club.com and do a search and then ask. They will be able to help you out alot better on this subject.Brian123 wrote:I'm trying to use one of these coolers to cool the oil in my 911 powered 356 replica. I've got a Mocal thermostat and it opens when the oil heats up and both lines are hot but not the cooler...nor does it seem to cool the oil. I suspect the internal T-stat is faulty and I'd like to eliminate it.
Can anyone tell me how to get rid of the internal T-stat? I've seen folks say use a bolt and nut to block the hole...can anyone who has successfully done this explain a bit more please?
thanks guys...
Brian
