It's pretty much limited by how loud you want it to be. A 3" exhaust on an NA KA with aftermarket headers would, for me at least, probably be too annoying for daily driving, even with a resonator.naed240sx wrote:For the ka, as it has been discussed many times, you can use a 3" system for maximum gains, but 0 losses, even if you are NA. Forget backpressure, velocity is most important.
i dont really know what's wrong w/ this thread... no one is really disagreeing besides what badmojo said. but, in all, he just means on a stock system, the bad side to larger exhaust is going to be the noise... hence, why silencers are made to make smaller.KDashy wrote:I remember a thread like this and I brought up the fact that exhaust gases come out in pulses and someone FLAMED me for it, unbelievable.
Nico members are generally smart but no one can agree on exhaust tech.
IBTL
Is that why the driving cat in your sig is shrieking in pain?lrb_2000 wrote:3" catback + no cat on N/A = loud. That's what I have, plus stripped interior,
lrb_2000 wrote:most likely... lol... it doesn't like to drive my car anymore.
Low end torque loss isn't as a result of losing back pressure.redrocket wrote:on an NA vehicle the less back pressure helps the car in the upper RPMs but can cause the vehicle to loss some of its low end torque
Wow, someone that doesn't have their head up their crack when it comes to an exhaust.IanS13 wrote:Turbo cars don't need any back pressure, between the turbo and the head inside of the turbo manifold is much more back pressure than any car needs or like, on any normal car before the converter there should not be more than 1-2psi back pressure after that you don't need any more, meaning after the converter 0 back pressure is perfect but on stock exhaust system that is not the case. so if you can deal with the noise a 3" catback exhaust on a na 240sx is ideal
you may ask what qualifies me will, I am a exhaust tech that's what i do
do you watch Bleach? lolyessir240 wrote:bwa ha ... bwa hhaha
