I believe it comes with a 2 year warranty...doubt I'll have the car more than a year (I got through cars like candy lol) but this is the first time a turbo has taken a s*** on me, so I'll looking for the most cost effective route to replace to turbo and have a set up as close to the one I currently have. Your saying that the ISIS replacement turbo from enjuku will be fine at 17lbs with the current tune(s) that the car is equipped with?compactfean wrote:I am the biggest skeptic when it comes to ”ebay” turbos but my friend has isis EVERYTHING. the t28 turbo is pretty impressive from them at 16-17 psi. I can't vouch for its longevity or hp difference but it kicks a** for what it.is. Only time will show its true durability though.
I've gotten quoted to have my turbo completely rebuilt for about $550...it's got some mad shaft play, and the rear seal is bad..the only way I would get the turbo rebuild would be if I could get it done for around 200-250$ (which I don't see being done lol) but PM me the info for sure!OutToWinPAHC wrote:I'd do the real deal but if you can get it cheap I can send you info to a company who can perform a quality rebuild cheap on that. Most of these chinese turbos have some casting imperfections, crap seals, and arent balance out the gate
was your 60 trim a ball bearing or a journal bearing?OutToWinPAHC wrote:San Diego forced induction he rebuilt my 60 trim for 200 and my toyota CT26 for 220 dude does awesome work, I have referred him to about 25 people so far guy is super legit, and very cheap (has a huge shop at his home, keeps overhead down and passes the savings)
http://www.sdforcedinduction.com
yeah, if it was a journal bearing, I'd have it rebuilt tomorrow! lolOutToWinPAHC wrote:Journal so yeah you cant rebuild that, but if you go the journal route have it checked out I can almost bet that isis unit is out of balance from the door.
OutToWinPAHC wrote:Enjuku will push ISIS all day, but at the end of the day some kid in a Chinese factory made it from the cheapest of parts they could get. I saw your post on Zilvia too, and they are what they are. I'm sure it would work, run a -4 feed with a .065 restrictor and dont crank her up too much.
keep me updated on how the turbo does! I'll keep this thread alive as I progress with the turbo as well. I don't plan on letting it see 17lbs too often...it will spike 17 and hold about 15-16ish. But for dd purposes I'll be tuned on either stock (which I know will be fine) or 12lbs. I'm going full ISIS: turbo, tubular manifold, and 3inch o2 housing...I had a massive boost leak on my last o2 housing to turbo connection, and the turbo was blown, so I haven't felt the real potential that the car had to offer, so I'm thinking when I bolt all this up I won't notice much of a power difference..compactfean wrote:Like I said, running one on my buddies car right now which is s14 head, bigger cams yada yada. Problem is is there is only about 3 months on a fresh motor and has only seen 16 psi like 3 times, and otherwise is tuned at 10 psi for dd. We shall see.
Kr5Kouki wrote:Wow, OP and I were in the same boat, between the same turbochargers. I considered the Isis 3078r and the S15bb T28. I drove a SR20DET with S15 turbo and fell inlove with spool time, boost pressure and compared to the ebay GT28 from GSP, the boost is more linear with S15 and the Garrett seems to last a lot longer. So I'm buying the S15bb
