*ISIS RS3360 Turbo Upgrade for the Nissan SR20DET
Look here for specials on Nissan parts, accessories or modifications, or tell our sponsors what you are looking for!
EnjukuBG
Vendor
Car: AE86
*ISIS RS3360 Turbo Upgrade for the Nissan SR20DET.
$499http://www.enjukuracing.com/is....html
ISIS Has just released their turbo upgrade option for the SR20DET. This is a great inexpensive replacement turbo for your Stock T25 or T28.
Big Performance in a compact package
This compact turbocharger offers much more top-end power than the the stock Turbos, thanks to a large 0.86 A/R exhaust housing. It offers good response on 1.8 litre to 2.2-litre four-cylinder engines.
Turbo Specifications: Compressor side inlet 60mm, outlet 50mm, 56-trim compressor; inducer 45mm, exducer 60mmExhaust side 0.86 A/R turbine housing, turbine wheel outlet 46mm, outer diameter 53mm
Results:On the SR20DET This turbo achieved ~280hp at 14psi. This turbo is rated up to ~330hp. (Very Similar to an S15 turbo)
Pre-Order sale this week only!$450 if you buy now before the next shipment comes in. Call or shoot me an email to recieve the special pricing.
Thanks,BG[email protected]352-241-8399
CaEric
Car: 91 Sr Pwred Coupe
what kinda boost are poepl running with these things!!!!
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
No need to yell!!!!!!! Although it is a decent question. A better question is... You're claiming more top end power... What kind of power are people achieving and at what boost level?
EnjukuBG
Vendor
Car: AE86
CaEric wrote:what kinda boost are poepl running with these things!!!!
Around 18psi.
PyR0NiAk wrote:No need to yell!!!!!!! Although it is a decent question. A better question is... You're claiming more top end power... What kind of power are people achieving and at what boost level?
More top end power as in 3rd, 4th and 5th gear, because of the bigger exhaust side. One of our customers made 280rwhp at 14 psi.
CaEric
cant wait to install mine......mail man needs to hurry the hell up ! what wast he the guys setup ?
EnjukuBG
Vendor
Car: AE86
Just a basic bolt on SR set up. Injectors, maf, tune, exhaust.
CaEric
hey so i got my turbo and i;am using my stock lines so i can get my car going...how ever when i go to put my oil-line in it doesn't bottom out....when i got the turbo there was a like a bolt that was unsable in the port for the oil line..was that a restriction or what ? cause if i left it in my oil line would bottom out.....
of if u could give me a ring in the am or some tim it would be great thanks !!! kinda hoping u read this tonight 8455598701 eric
PyR0NiAk
CaEric wrote:hey so i got my turbo and i;am using my stock lines so i can get my car going...how ever when i go to put my oil-line in it doesn't bottom out....when i got the turbo there was a like a bolt that was unsable in the port for the oil line..was that a restriction or what ? cause if i left it in my oil line would bottom out.....
Eric, I really doubt a business is going to call you to give you tech support.. Try going to enjuku's website and calling them.
EnjukuBG
Vendor
Car: AE86
Just spoke to Eric, he was just confused about the oil feed restrictor. He should be all set and ready to go! But with any upgraded turbo, I would buy upgraded turbo lines, makes the install 10 times easier .
CaEric
10 times easyer yes...yes but it was done gonna order lines and a gasket set and clutch with in the next week or so!!!thanks for the call this morning !!!
zeause
I was wondering if the turbo came with any kind of warranty and if i could run it on a stock sr for awhile until i upgraded injectors and maf?
EnjukuBG
Vendor
Car: AE86
zeause wrote:I was wondering if the turbo came with any kind of warranty and if i could run it on a stock sr for awhile until i upgraded injectors and maf?
You can put it on a stock sr. But I wouldn't run anything but stock boost until you get the maf and injectors. ISIS warranties are pretty simple. Give us a call, let us know your problem, and if the item is what failed, we'll replace it
zeause
That sounds like a great deal Ill be ordering one shortly. Thanks!
newcharles
That's really wonderful turbos!
Return to “Advertisers' Marketplace!”
