ISIS Oil Pan? any reviews?
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
hey i just saw the isis oil pan from enjuku for only 125. thats a awesome price..
is it aluminum?
any reviews?
heres a link..
http://www.enjukuracing.com/isis-nissan ... -8308.html
i dont want to hear you flame isis becuase they are cheap, i know, but its only an oil pan, nothing too technical imo
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
I'd say keep OEM.
OEM oil pans are the strongest because they're stamped steel. Anything cast is gonna be weak when you smash it off the ground.
badbob2121
well they say its a alternative to the greddy, and ive heard on people dropping their sr20det on the greddy and it survived and was still perfectly fine
oem are only like 83 bucks too though
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
I have it on my ka24ert and i love it. side by side it looks nearly identical except the isis one has a slight bowl for the oil to gather underneath the oil pick up tube.
badbob2121
hmmm... i think ill go with the isis... higher oil capacity ftw...
krash
Never tried the oil pan, but I do have an isis short shifter and an isis high pressure steering hose. They make some quality stuff
Justin35ll
Car: s13 coupe sr20det
I have the isis oil pan on my sr20.
The bad:
Pan comes with (10?) allen head bolts. I think I only used 8 of them because the other 2 were too long and bottomed out before tightening it down.
The pan has a nub on the inside of it that hits the oil girdle. I guess you could grind the pan away, but at the time it was just easier for me to cut the girdle until the nub cleared it.
The plugs they give you arn't tapered and don't have a head on them so you will need to get a new drain bolt. I used a NPT fitting that worked well.
The good:
The pan fits great, does not hit swaybar or anything else in the area.
Does not hang lower then the sway bar ( I have excessive solid engine mounts I don't know know if they are different then stocks)
Cheap alternative to a nice pan
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
I wouldn't skimp on something like that, i mean the moroso is a great pan and is around $300 or less if i recall. Plus its not cast.
