ISIS Intake mani bracket
sl87
Car: nissan 240sx
I got the ISIS manifold and came with this bracket. I don't know where it goes on the manifold. Can anyone help me out with this?
Justin35ll
Car: s13 coupe sr20det
I don't know, can you use the stock mounting brackets with that manifold?
sl87
Car: nissan 240sx
No I dont believe so. Theres only one hole on the underside of the manifold that a bolt goes into, I was placing this bracket in different spots but just didn't match up with any other bolt holes. The bracket confusing the hell outta me. Anybody??
V8slayr
Car: 97 240sx
I just started to install mine the other day too but didn't make too much progress, I have to wait on IACV and throttle body gaskets. But even w/ some looking around I didn't figure it out either. I should be able to complete it by next week so I'll be checking this thread again hopefully finding the answer, Good luck
Also, if you get a chance post up some pics of your coolant line routing and fuel line routing. I'd like to get a look at it before I actually do mine.
sl87
Car: nissan 240sx
Yah I haven't even started on fuel line setup yet, but as for the coolant lines Im gonna be running s14 water neck(which is for sale) so i cut the coolant line that runs in the back of the motor and prolly just bypass it or run to the heater core. Dont know yet. What I have in the pic is all I got done as for coolant. The only two lines i dont remember how to run is the hard line nipples next to the temp sensor. I know theres a thread on it, just gonna search for it.
As for this damn bracket...cmon guys i know theres a bunch of you running greddy, freddy, top speed, ISIS manis out there.. drop a line.
Just to let you know V8slayr you can use a ka throttle body gasket as to my knowledge. I was about to spent extra ten bucks getting it online when I could of just gone to my local auto store.
sl87
Car: nissan 240sx
bump
justclay
Car: 1993 Nissan 240SX SE Convertible
I would email the guys at Enjuku. They should be able to tell you. They sell that kit on their website and should know what the deal is with the bracket.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Does it go between the new manifold and the factory bracket?
TKOcrewSR
Car: 1990 nissan 240sx
i was looking to se if i had a picture from my greddy intake but i dont.it does go between the intake down to the bolt that goes to the alternater has two brackets that go to it. if you can take a picture close of the intake side of you engine i can point it out for you.
TKOcrewSR
sorry wasnt paying attention to the picture you had up already. but from what i can see it goes to the bottom of the intake and to the bolt on the alternater bracket just above the 9 in 2009.
