Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Mon Aug 11, 2003 10:59 am
What's larger, the rotor diameter (sorry, not familiar with this brake...hell, I didn't even know it would work w/ a 240)? If so, that = more brake torque, which will improve your braking (and feel). Not only that, but heat will dissipate better so you you'll have less of a fade issue as well. Caliper upgrades are only really needed if the existing ones don't provide enough clamping force to lock up the tires IMO (or if you want wider rotors).
So, what's needed for this upgrade anyway? Is there a brake line issue like with the z32's? I'm assuming the p-brake is like the s13's, so that shouldn't be a problem... Fill me in!:)
