fabio420 »
https://forums.nicoclub.com/fabio420-u28809.html
Tue May 24, 2005 3:56 am
I don't know about the kit blowing up and all that, but it is true. You can basically buy all the components, including an SAFCII for $1400. I put a T3 turbo in my car, with a 27" bar n plate intercooler, SAFCII, turbo timer, new fuel injectors(370cc), wastegate, blow-off valve, downpipe, oil lines, ic piping, 3 different guages, and even a heat containing system(heat wrap) for my turbo.Do the research and you can come out on top with that money. P.S. You have to do all the work yourself, even welding, or the cost will hike up considerably.
