Is this wire suppose to be hooked up?
tay-fu300zxtt
Car: 300zxtt,
It's a rb26 swapped in a z32
Looks like pin 47 black with yellow stripe..
PapaSmurf2k3
Site Admin
I don't suppose you have bigger images, do you? Those are only like 100 pixels.
tay-fu300zxtt
Car: 300zxtt,
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
It looks like its for the check engine light.
Carl H
looks to be ignition signal (key on) so answer is yes, a lot of stock nissan ecus will not start or behave properly without the signal and some standalones require it as well.
jabbacalvin
Car: S13 RB20DET
Carl H wrote:looks to be ignition signal (key on) so answer is yes, a lot of stock nissan ecus will not start or behave properly without the signal and some standalones require it as well.
Carl H! I just got a rb20 s13 that needs a tune. Is it possible if I could have your email to contact you for a tune?
tay-fu300zxtt
Car: 300zxtt,
zfever did the engine harness... called and sent them the picture. They said it was the starter signal and that it does not need to be hooked up. The car turns over and the ECU comes on.
