Q45tech wrote:The problem is how to disassemble the two piece driveshaft and maintain or rebalance to spec.Foam is used inside the shaft to stablize the actual driven core, eventually gravity and rotation takes its toll and the shaft should just be replaced.
Even the improved 94 just prolongs the eventual demise instead of 100k life the new one goes 150-200k.
When things are only designed to last [stay in spec] for 100k you get to rebuild and rebuild.
The problem is/was that the shaft had to be able to survive ~~ 6900 rpm [1:1 in 3rd gear] very few lux cars had that high of a limit.
My 2nd new shaft is approaching 200k and the telltale signs are starting and I had it on car strobe rebalanced at 100k, I try again but unlikely I can get it to hold for more than a year or two.
So, a shaft from a 92 with 10k (I think) would be just fine and last problem free for the next 90k?
So I can't replace the shaft in the driveway then right?
