Say what?Paul Wall wrote:Is this a good ultrasonic cleaner: http://deatchworks?
I've been thinking about your cleaning question since you asked about it in another thread a few days ago. An ultrasound jewelry cleaner like the one you posted came to mind but it really doesn't clean the path that the fuel travels since the injector will be closed.Paul Wall wrote:I want to clean my injectors since I have 6 that are off the rail and another 8 on my car, But how can I clean them my self without sending them to deatchworks?
No I ohm'd 6 that were in that range and the other two were dead on was 35 or maybe 3.5 and the other one was like 16 i think.The connectors were all green so i'll be cleaning that and ohming them again once i install the rails back with the injectors.I need to know how to do the compression test on the rails.If it's not necessary then nevermind.goody94q45 wrote:Is this all 8 injectors or just the seven? If all 8 are now ohming in range you've got to suspect you may have a bad injector harness or had heavy corrosion on #3 (or was it #4) injector pins. How did the injector pins look? Clean or green? Is the harness brittle? Have you done a continuity/resistance check on each lead from the 8 pin connector to the injector connector?
Nope, power flush coolant, hydraulic fluid in brake lines, and mechanically exchange ATF simultaneous fill and extract PS fluid. Cursory familiarity will reveal even fuel is moved under pressure with a pump. Differential is only gravity drain and fill on my cars! Pressure differential is your friend when evacuating and installing fluids!qship96 wrote:Brian forgets that he performs regular drain and fills every time he fills up his gas tank then the engine consumes the fuel. Geez get real!
Bet he does drain/fills on his coolant too....not worth messing with block drains.
And move those injectors to accessible locations that don't require removing the plenum again!goody94q45 wrote:Money's tight Berner and when we did the power balance test on your Q all the injectors checked out about the same. None were plugged and only the 2 were ohming out of range. Get her back together .....
If im doing anything wrong when removing the plenum please come foward and tell me.Or better yet let's see pictures of you doing it.maxnix wrote:And move those injectors to accessible locations that don't require removing the plenum again!
Or you'll be sorry very soon.
...members' standards vary...qship96 wrote:Brian forgets that he performs regular drain and fills every time he fills up his gas tank then the engine consumes the fuel. Geez get real!
