crackler »
https://forums.nicoclub.com/crackler-u26495.html
Wed Feb 22, 2006 2:42 pm
A freind of mine gave me a t25 and a smic out of a 95 talon for free.
It has 2" inlet and oulet on the compressor.
my question is, is this thing worth using?
I am new to turbo's, I have been looking around DSM sites trying to find info on this turbo. It was originally on a 2.0 liter that made about 210 claimed hp, I assume bhp. I still havent found what psi the internal waste gate is set at.
I think it has a t25/t28 flange. And a ported inlet from the exhaust side (where the flange bolts to the mani)
This is a garret unit, at least that is what the metal tag on it says.on exhaust wheel it has .49 n55 439 h2 (exducer 1.590 inducer 1.830)on the compresor side it has .48 m10 1 (exducer 2.055 inducer 1.525)
I assume the first set of numbers are the a/r or trim? I dont know what the diffrence is any way, but I have no idea what the rest of the numbers are.
I was planning on using both the turbo and the smic, fuel pump, injectors, fuel controller,(possible safcII), bov, dump pipe, boost and other misc gauges and possible a mbc, and all of the other associated parts (water lines, oil lines etc etc)
Sould I use this thing or should I just wait save up and get a bigger turbo?
I would like to be in the 230 - 250 whp range. I don't really want to run more than 10psi, I was planning on running around 5-7. Is that a resonable expectation with this set up? I do alot of autoXing and some HPDE's so I want something with quick spool up.
Please give me you opnion, I know enough to know I dont know.
Surry for the long post.
Thanks.
