Is this turbo good for a CA....wanting approx 300RWHP?
datsunboy
Car: Datsuns
I'm wanting a new turbo for my CA....would like to be able to have approx 300RWHP.
"you are bidding on a new 440hp T04E/T3 turbo by XS Power,This turbo uses a garrett T04E 51mm compressor with .5a/r
The turbine uses a stage3 .73 trim 62mm with .63 a/r housing. with T3 flange.
This is perfect for any dohc turbo application and should be good for 400hp+"
Oh and just found this one....
"BRAND NEW T3 TURBO
" XS POWER "
T3/ T4OE TURBOCHARGER
STAGE III WHEEL
BRAND NEW
3" INLET DIAMETER
2" OUTLET
WET FLOATING BEARINGS
1/8 NPT OIL INLET
T3 / T4 FLANGE
FITS T3 AND T3/T4 MANIFOLDS
SPECS:
. 50 A/R COMPRESSOR
.63 A/R TURBINE
.57 TRIM
THIS TURBO CAN EASILY DO 25 psi
Great whp ON B SERIES SWAPS
Standard T3 Flange,
Perfect for any 4 cylinder.Mitsubishi Eclipse, Honda Civic, Prelude, Integra, Ford 2.3L Turbo Etc.
TURBINE WHEEL:
EXDUCER: 2.48"MAYOR : 2.89"
COMPRESSOR WHEEL :
EXDUCER: 2.07"MAYOR : 2.36"
5 BOLT FLANGE
HAS A HOLE FOR INTERNAL GATE APPLICATIONS IF YOUWANT TO USE A T3/T4 WITH AN INTERNAL ACTUATOR - YOU CAN
OR
YOU CAN USE THIS WITH AN EXTERNAL GATE"
Both are around the $900 mark.( I do realise I'd need a new manifold )
Modified by datsunboy at 9:28 PM 2/22/2005
djmace
XP Power Turbos = Junk Muff Said!
NeedCAforS13
Car: CA swapped S13 coupe
XS power is crap and that .73 turbo is way too big for our 1.8 liter.
Sean
datsunboy
Car: Datsuns
Can anyone give me an idea on some specs then?The car will be my daily driver, so dont want much lag.looking for approx 300 RWHPeither to fit a T25 flange, or a T3 flange.Internals are stock at the moment ( but all new ).450cc injectorsand will get a Z32 MAF once I sort out a turbo and manifold
datsunboy
Car: Datsuns
also would PREFER to have a Integral wastgate???
silkroadS13
Car: 1993 Nissan 240sx
i'd look at a ball bearing turbo, since you were looking to avoid lag as much as possible
a GT28RS should get you close to there, and I know someone is selling one with a T3 compressor housing that should get you pretty damn close to 300 hp
RMiller
Car: BBQing
2871R .64 (or .63, I forgot). It's about $1k. Or an hks 2530 but that's pricey.
ca18detizzle
jdmDAvey
Car: 89 Fastback..CA18DET, Front Mount, Kei Office Coils, Mandrel Bent 3"!
go T3 super 60
djmace
GT28R
boost_boy
jdmDAvey wrote:go T3 super 60
In a T3/T04B stage I wheel with .63 housing or even a .48 and you will have the best of all worlds (ie cheap price, quick spool-up and flexible).
Dee
