Is this timing chain too loose?
dsagers
Pulled the front cover to replace the chain guides, and noticed the driver side chain has some slack. Is this too loose, or is the chain OK?
ScottJackson
Car: 91 Q45, 92 Q45a, 93 Q45, 79 BMW 635CSi, 95 BMW 540i
Nope. Should be fine. Those are the new style guides. I posted a while ago how to check them with a small hole drilled in the front cover (saves a lot of effort, just need to pull the four 10mm bolts for the fan and the fan). That slack is normal. When the cams want to turn clockwise (when viewed from the front) they'll put slack in the chain like that after the engine has been shut off a while. The tensioner on the other guide (the curved one) will pump up quickly when the engine is started and remove the slack. You're good to go!
mxr662
Car: 1990 Q45 Desert Sand 81k Sold
Depending on the mileage might consider replacing or at least adjusting the oil pump chain as it does stretch.
Andy
