Is this the right engine for my pathy?
Pathfound49
Car: 2003 Nissan Pathfinder
2005 Volvo XC90
1999 Volvo S70
Every time I go to do a repair on my truck, I see some things that just don't jive. According to the paperwork, I have a 2003 Pathfinder SE. Now most of the time, the parts are the same. But in this case they are not. I'm replacing the crankshaft position sensor. The sensor for an '03 and '04 3.5L are completely different.
Does anyone know how to determine engine year? Is there a code in the vin#?
Any help would be appreciated.
asnorton44
Car: 2001 Infiniti QX4
Well if you have an 2003 then get a crank sensor for a 2003. You can see them here:
http://www.partsgeek.com/catalog/2003/n ... ensor.html
I just replaced mine a month ago, also in the drivers side door jam you can get your MFG Date atleast.
Pathfound49
2005 Volvo XC90
1999 Volvo S70
That's the problem. I did get an '03 crank sensor. The one by the oil pan. It is not the same(i didn't get the wrong part because various websites state so). I looked at an '04 crank sensor, and that is the same as what came out of my engine. I knew my truck was an auction vehicle, but had no idea that an engine swap may have occured sometime before I bought it. Something not normally shown on a carfax report. Thus the question.
And why the difference in sensors? Same 3.5L, right?
Pathfound49
2005 Volvo XC90
1999 Volvo S70
Thanks Infiniti. Apparently, there is something regarding manufacturing date that applies to this sensor. Prior to 01/03 was one type, and after was another. I would personally like to thank the Nissan brain trust for that.
Pwnin O'Brien
Here's an easy way to see if your engine is for a 2003, if your throttle body is electric and not mechanical then you have the correct engine.
Pathfound49
2005 Volvo XC90
1999 Volvo S70
Thanks Pwnin. In the future, date of manufacture will always need to be considered when shopping for replacement parts.
