jdanielsg »
https://forums.nicoclub.com/jdanielsg-u36024.html
Fri Mar 21, 2008 10:48 am
I was doing my grounding wires and I am trying to figure out which one is actually my ECU there are metallic boxes in that vicinity ones at the bottom right edge of the foot well one is above that hidden next to the air filter so you can only see it if u wedge yourself in there and look up and right...
Here is a picture of the footwell with the glovebox removed and the right side kicker plastic trim removed:
This a close up to the stuff you see in the picture above on the right corner, says Nissan on it and all that:
Now, right above that and further front maybe a few inches right next to the firewall, hidden from view and only be able to see if you stick your head into the cavity and look up... is :
The view of which is looking up, so you are seeing the bottom of it, and next to it the white plastic is the cabin filter/fan (its this roundish plastic housing). You can see my grounding wire hooked up there because I think thats the ECU ?
Let me know guys. THANKS!!
