Is this the complete strut (loaded)?
AJ170
Car: 2012 Infiniti M37x
2012 Infiniti M37X (AWD)
From Amayama
ABSORBER KIT-SHOCK,FRONT
Genuine Nissan (E61111MD0B)
https://www.amayama.com/en/part/nissan/e61111md0b
AJ170
Loaded as in it has the top mounting braket and spring, direct swap.
Yoda's Master
Car: 2012 M56
2009 370z
doubt it. looks like just the shock and 4 nuts
AJ170
Yoda's Master wrote:
Fri Mar 13, 2026 7:34 pm
Looks like im SOL, cheapest I can find front left AWD strut is $250 unless i want TCS but thats $80 and you get what you paid for compared to the oem KYB strut. Was hoping to get a new strut for $180-220 but Im not seeing it that low.
Yoda's Master
Car: 2012 M56
2009 370z
AJ170 wrote:
Sat Mar 14, 2026 4:34 am
Don't understand the problem. Just reuse the existing spring and mount.
Ilya
Sat Mar 14, 2026 3:14 pm
This. The spring is a lifetime part unless you did something to it like heat it or cut it. All you need is the long strut, which is available.
I personally look for loaded struts too as I HATE working with spring compressors...but that's the only reason.
Yoda's Master
Car: 2012 M56
2009 370z
You don't need spring compressor, just a jack and jack stand. Remove the center nut while your car is still sitting on the ground and slowly lift the front, remove the wheels and remove the dead shock. Replace the shock and use a jack to lift up the lower control arm while guiding the shock into the mount. Put on the center nut and turn it enough to hold the shock in place, put your wheel back on, drop the front end and tighten the center nut with the car sitting on all four tires. You don't even need to remove the mount from the car.
Ilya
Wed Apr 01, 2026 10:36 pm
This is actually pretty great hah.
madmanpauly
Car: 2011 Infiniti M56S
I've been thinking along the lines of replacing them with these. Pretty cheap alternative right?
https://ebay.us/m/UwN5y0
Ilya
Very cheap. Might not last long.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
madmanpauly wrote:
Wed Apr 08, 2026 5:47 am
Ilya wrote:
Wed Apr 08, 2026 6:13 am
The complaint with most of the eBay shocks and struts I've seen isn't that they wear out, it's that they're made very, very stiff so they don't wear out. Don't be surprised if they wear fine but affect your dental work.
:naughty:
madmanpauly
VStar650CL wrote:
Wed Apr 08, 2026 6:39 am
:naughty:
LOL - I have the M56S with the 20" wheels so I went up in tire size by 1" to give it a smoother ride. This might help with the stiff suspension. I'll let everyone know how it goes.
The story is that I've given the car to my son as his first vehicle. The shocks are going and the paint is fading so he probably won't have it long. The engine and drivetrain is tip top so I'll post it here when the time comes to sell.
Q70sGuy
Car: 2015 Infiniti Q70 S
I bought all of it from Amayama. There’s no equivalent alternative to the OEM for AWD in the front and I wouldn’t put on an aftermarket set unless I did all 4. Also, springs are different for sport and non-sport models.
If the strut boots are in good shape then you don’t need to change that top mount. I would get the small spacer at the top if I did it again however, because mine had a rip in it and it’s relatively important to prevent corrosion. Front springs are unlikely to need replacing, but in a salted roads area the rear springs will 100% break and you won’t notice it because it breaks at the very top. If no salted roads then you’re fine with just struts. You can bring the new and old to a shop nearby and theyll probably charge you a couple bucks to swap over all the parts for you.
