is this the clutch block?
s13point5
Car: 89 240sx
can anyone tell me if this is the clutch block that im suppose to remove?
because it doesnt look like the pictures from this link:http://www.nicoclub.com/articles.php?id=251959
even tho it doesnt look like it, i still cant get my clutch to bleed correctly.
verSat1l3
Car: 93 S13 Fastback 96 S14 SE
What the? Damn its an 89 I don't recognize that... It looks like there is no damper loop. Make sure you bleed at the slave cylinder and it will probably work. Push the pedal in, open the valve, close the valve, and then pull/return the pedal out. Repeat as necessary. You might have to bleed that block first, but it doesn't look like it traps a whole lot of air...
Sears just had a sale on the vacuum bleeder kits for $20. Thats the way I'm going with mine.
