Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Mon Dec 13, 2004 5:37 pm
Ok, here's the low down.
This is a 1994 R32 RB26DETT motor. This "block box" looking thingie has no harness that goes to it. The wiring for it appears to be separate from the main ECU harness; the harness that plugs into this I do not have. I suspect that this is the Boost Cut Solenoid, but this is just a guess.
Basically, what is this? Is it required? There is a small vacuum line that comes off the rear side of the throttle bodies directly above Injector 6. That vacuum line then leads to this black box thingie. WHAT IS THIS?
Thanks all.
