Ive tried sitting in the car with a stop watch, and adding a few second to each key on and off, to make sure I wasnt doing one premature or something. But it isnt working.
12 RESET THROTTLE POSITION SENSOR IDLE POSITION MEMORY
Without CONSULT-II
NOTE:
Always warm up engine to normal operating temperature. If engine is cool, the throttle position sensor idle position
memory will not be reset correctly.
1. Remove feeler gauge.
2. Reconnect throttle position switch harness connector.
3. Start engine.
4. Warm up engine to normal operating temperature.
5. Stop engine. (Turn ignition switch “OFF”.)
6. Turn ignition switch “ON” and wait at least 5 seconds.
7. Turn ignition switch “OFF” and wait at least 10 seconds.
8. Repeat steps 6 and 7, 20 times.
This is on EC110 of the 2001.5 FSM
Is there any easier or more clear cut way to do the test?? Id love any help on this. Im screwed to get to work tomorrow
