RedRum240 wrote:Boost Designs Stage 1 KitMSD 50lb Injector'sJWT Fuel RailJWT ECU UpgradeCobra MAFApexi SAFC2Apexi Boost ControllerWalboro 255 lph fuel pumpZ32 Fuel Filter
Does that sound like an ideal set up to be running about 12 PSI boost and be safe? orcanm you guys suggest anything else that might help me tune the turbo or that will be needed to have a perfectly running turbo.
Why would you need SAFC if you're using JWT ECU - it already does your air/fuel & timing adjustments, and they have specific programs for most MAF & injector combos...
